688 Morris Quad Field Artillery Tractor (1957-70)
15 years 3 days ago #1391 by Richard
Hi everybody.Does somebody know if this tractor was issued without driver in the later version ?I got one from england, with plastic wheel hubs, perfect windows and the baseplate was not removed !Does somebody know how was fixed the driver in the van ?Thank you for your answer.Cheers
15 years 1 day ago #11392 by buzzer999
Hi Richard As far as I am aware the 688 Field Artillery Tractor was always supplied with a driver, the only change was from a metal driver to the plastic driver late in the production run. If you look at the photograph above you will see that there are two bent over lugs coming through the baseplate, this is the attachment for the driver. Alongside the tractor is an example of a military driver sat on his support/seat. These supports vary in height according to which vehicle the driver will occupy. I hope this helps Dave B DTCA Editor
15 years 1 day ago #11394 by buzzer999
Richard Is it possible for you to add a photo of your 688 baseplate/ Thanks Dave
15 years 1 day ago #11395 by Richard
Here it is ...... if I succeed
15 years 1 day ago #11396 by Richard
No, I did not ! I try again
15 years 1 day ago - 1 year 7 months ago #11397 by Richard
15 years 1 day ago - 1 year 7 months ago #11398 by Richard
and here are the windows ; durty but not broken !
15 years 1 day ago #11399 by Richard
Soory .... dirty !
15 years 23 hours ago #11400 by buzzer999
Hi Richard Looking at the baseplate on your tractor the driver support/seat is definitely there so it must be assumed that a support without a driver was fitted and this is an assembly error which occurred at Meccano. I have seen one of these with the driver fitted backwards!!! Sadly, unlike stamps, errors like this do not make the Dinky valuable. Dave
15 years 22 hours ago #11401 by Richard
Thank you Dave. I have one with the driver fitted backwards and I think that I sent photos to the post of 'Manufacture errors'. I am going to verify.
15 years 22 hours ago #11402 by Richard
it's in the post 'factory errors' , page 7 ;)
14 years 11 months ago - 1 year 7 months ago #11411 by janwerner
Another 688 oddity here. Of the two 697 sets I have the tractors are equipped with different towing hooks. The later windows example does not have the usual rebent hook but a regular upright one. I'm not 100% sure if this is original because the straight hook is not fully straight and might have been rebent, but in that case it would have to show a much longer piece of tin. Do others recognise this oddity in their later 688 models? Some pictures below: Kind regards, Jan
Time to create page: 0.451 seconds
