149 & 1413 Citroën Dyane
10 years 9 months ago #7527
149 & 1413 Citroen Dyane was created by Richard
Following this morning arrival, I think it's time to open a new topic on this Citron. First photo : Both sisters with their different wheels. By the way Jacques, the grey wheels are not the same than those you show in your encyclopaedia. The tyres are marked 'DUNLOP' Second photo : The two sisters with their frenchcousin, which is very happy to have found its box ! Third and fourth photo :This time the bonnets and the rear hatch are staying open very well, without any help ! You can see the little design variation between the english and the french engine. (just behind the radiator) Fifth photo : The base plates. As the greywheels are thinner than thespeedwheels, the rear axle is protected by some kind of pipes, on each baseplatesides. Unfortunately the previous owner as put some stick on the french base plate ! That's all folks. Richard
10 years 9 months ago #17819
Replied by dinkycollect on topic 149 & 1413 Citroen Dyane
Citron or Panhard ? When the real Renault 4 was issued, Citron decided to re-look the 2cv but the design office was busy with other matters and could not do the job. As Citron had just bought Panhard and that the Panhard design office had little to do, it was ask to design a new car based on the 2cv. which they did. At that time, Citron were designated by a combination of letters such as DS, CX, AZL, AZAM etc... but amazingly the naw car was named DYANE, a peculiar name prety close to DIANE but not quite. The reason is that Panhard had registered several names starting with DY such as DYNAMIC, DYNA and DYANE. So the name gives away the real parents of this car.
700 286 Richard, Je n'avais pas encore vu le dessous de la Dyane anglaise avec jantes tournes. Pourrais-tu m'en faire une grande photo au moins aussi grande et aussi droite que celle-ci ? Je pense que la variante de moulage l'avant du moteur est due l'usure du moule et n'est pas dlibre.D'autre part je n'ai rien sur la variante Espagnole. Connais-tu quelqu'un qui en a une ?Merci d'avance.
10 years 9 months ago #17820
Replied by Richard on topic 149 & 1413 Citroen Dyane
Hi Jacques. I think there is a real engine design variation between the cousins. Here under, a new photo showing 2 different details : The air filter is much bigger on the english Dyane and the space between the air filter and the radiator has been filled. Also a new photo of the baseplate of the grey wheels variation. I don't know what kind of material they are made with. If it's not good enough for you, I will make an another one ! (the daylight is dark to day) Friendly yours Richard
[img]/images/sites/default/files/forum-images/Citroën Dyane (12).jpg[/img]
[img]/images/sites/default/files/forum-images/Citroën Dyane (11).jpg[/img]
10 years 9 months ago #17823
Richard, Thank you for the picture although it is not very sharp because of the fog which we have had in the last three days. A better picture will be welcomed when the natural light improves, probably after to morrows elections.Are the spacers on the rear axle in two short pieces or a single long piece ? In the mean time, have a nice x'mas. Jacques.
10 years 9 months ago #17824
Hi Jacques.* No problem. After the elections the sun will shine ! I will post it on your private address. The spacers are in two short pieces. Nice x'mas to you and happy new year. Richard
10 years 7 months ago #18026
10 years 7 months ago #18027
Many thanks Richard this completes the set of four different base plates for te same casting. Probably a record.I agree that the boss in front of the air filter's pipe is larger on the English issue and then certainly on the Spanish one. It must have been enlarged at some stage. Do any French Dyane have this enlarged boss which contains the assembling screw or do any English Dyane have the small boss.I will investigate this to morrow. All the best.Jacques.
10 years 7 months ago #18032
Time to create page: 0.597 seconds
