25P Pick-up Studebaker
9 years 3 months ago #7817 by dinkycollect
The Studebaker pick-up and 25 S two wheel trailer are made to be together. One could think that the rear beds were cast in the same die.The chinese counterfeit shows that the red rear bed of the pick-up and the trailer are cast in different moulds. The rear lights are recessed on the pick-up and raised on the trailer. Also the trailer is 1 mm. narrower (33 mm.) and 2 mm. (14 mm.) lower than the pick-up (34 mm. and 15.3 mm. respectively). QUESTION : Is this the same on the Bobigny issues ? The pick-up is not a 'camionette' but a truck and it's scale 1/55 does not match the trailer's 1/36 if we consider that the trailer is a Bantam jeep trailer.
9 years 2 months ago #19917 by Dinkyman
Replied by Dinkyman on topic 25P Pick-up Studebaker
Hello Jacques, My pickup and trailer have different castings: - The measures are the same (33/15 mm). - The rear lights are larger on the trailer, all are recessed. - There is a notch over the hook on the pickup. - The bottom of the trailer is flat whilst the pickup has mouldings to secure the chassie. Best regards, Ragnar
9 years 2 weeks ago #20112 by dinkycollect
Replied by dinkycollect on topic 25P Pick-up Studebaker
600 377 Terry, Your covered pick-up is wrong.It should be as above. The brown tilt is from the covered trailer ref. 25 T.
9 years 2 weeks ago #20115 by dinkyfan
Replied by dinkyfan on topic 25P Pick-up Studebaker
Jacques.....Yes, I think someone just assembled that one. I will go in and delete those photos so not to confuse anyone. Best regards, Terry
9 years 2 weeks ago #20110 by dinkyfan
Here are some further photos of the Studebaker Pickup truck. Best regards, Terry
Time to create page: 0.506 seconds
