596 Arroseuse-balayeuse L.M.V. [L.M.V. Road Sweeper/Washer] (1960-1963)
10 years 10 months ago #7476
- bakalkeeling
10 years 10 months ago #17484
by bakalkeeling
Replied by bakalkeeling on topic 596 Arroseuse-balayeuse L.M.V. L.M.V. Road Sweeper/Washer (1960-1963)
The software is not what ' s at issue here - it ' s a matter of correct coding.Allow me to correct your image inserts so that you can examine the structure.This forum uses html tags - the old vanilla / BB - type forum tags with the square braces [img]and closing tag labels [/img] are not supported here -and increasingly not supported anywhere due to the security issues they generate.In html,the img tag has no closing component exceptfor a & gt;The only parameter required afterthe identifier is the src parameter,which is a path to an image hosted somewhere on the internet.For example;[img] http: / / i924.photobucket.com / albums / ad90 / maofords / 596 - Bleu.png [/img] To ensure that this form of code is entered correctly,I advise you to use the Image icon that is available in the top row of the text - editor window.Paste your image path into the first fieldand click OK.The system will then insert your hotlinked image correctly.Simply pasting a link into the editor window will fail.
10 years 9 months ago #17483
Replied by dinkycollect on topic 596 Arroseuse-balayeuse L.M.V. L.M.V. Road Sweeper/Washer (1960-1963)
[img] http: / / i924.photobucket.com / albums / ad90 / maofords / 596 - Bleu.png [/img] Collection l ' Auto Jaune This is a unique model.On the box is written: ' Sample painted by LMV for Firenze (Italy) '.It is likely but not confirmed that a small batch of these sweepers has been painted by LMVand sent to a potential customer in Firenze,may be the city of Firenze.
10 years 9 months ago #17493
Al,How come that the picture at the bottom of my post does not show anywhere when I edit the postor in the source ? How can I delete it if it does not show ? I have a limited knowledge of.html but enough to have written a document with 3 000 pagesand over 10 000 pictures.The site should host it ' s own pictures,they MUST be uploaded to the server when one clicks on the upload buttonand they M U S T show in the codeand in the edit window as soon as they are uploaded.There is absolutely no alternative,this is how the forum MUST work.Forget about the bucketand all these complicated mercantile web sites.All the other forums are junk,a post must be able to have picturesand captions underand above the next picture.Also different text sizeand styleand different alignments in the same post.Please make things as simple as possible,no useless functionsor pages.Jacques.P.S.This post was saved in size 20 ! ! !
10 years 9 months ago #17495
This thing will not save a picture without any text.This is an other reason for uploading the picture on clicking ' Upload 'and showing the picture straight away.This is an evidence.A kid aged three would understant that.The dam picture is there but it does not even show in the code ! ! !
[img]/images/sites/default/files/forum-images/Image 2.jpg[/img]
- bakalkeeling
10 years 9 months ago #17497
by bakalkeeling
I hope you don ' t mind if I tackle these queries one at a time...So...There are two ways to upload an image.1) At the bottom of each text editor to ' Addnew comment ' there is multi - uploader with the option ' Adda new file '.Browse your computer,click uploadand click Save when you are all done creating / editing the rest of your post / comment.That ' s the easy way -and exactly what you were asking for,Jacques.2) DavidK said that some members were specifically asking for the ability to insert inline imagesand craft them together with their text content.They want to enter some text, addan image,a bit more text,another image / s,more text,another image,and so on.That ' s a more complex requirementand requires a different approach,which is as follows - Click the Image icon found in the top menu of the text editor panel.This gets an image insert dialog box.Click Browse Server,click Upload,Browse your computer for the image,Click Open,Click Upload,Click Insert.Yes,there are more steps with this method but the the sequence of clicks would become quickly familiar aftera couple of uploads.Jacques,your post has both kinds of uploaded images - inlineand (the last image) through the file uploader.If you click edit on that post,you will see that the image 596 - Blue.png is listed in the file information panel just above Save.The option to remove that imagesor addmore images is there also.
- bakalkeeling
10 years 9 months ago #17498
by bakalkeeling
Whatever html document that you might have authored previously,Jacques,it must have used html tags.All your html image tags will be in the format & lt;img src = ' aPath / aFile.jpg [/img] & gt;.The tagging system which uses [img]...[/img] is not html.It is called BBcode - developed for the old vanilla BBforum modulesand is a deprecated technology because of its inherent security risksand lack of strict standards.I believe the now dead TMT forums used BBcode.Although I could permit the use of BBcode here,I am reluctant to godown that path because it would superimpose another setof methods over the existing html set-and even you,Jacques,are saying you want less complexity rather than more.
- bakalkeeling
10 years 9 months ago #17499
by bakalkeeling
If you want to hotlink to images on photobucketor elsewhere,this is possible by clicking the Image iconand pasting the image path into the first field.That ' s an option - but on the whole,Jacques,I don ' t disagree that the site should ( and does) host images.Using the easy file uploader,the process takes,what,three clicks ? Browse for the image on your computer,Open it,click Uploadand Save.In fact,I think you don ' t even need to click Upload,so long as you browsedand opened an image - the system reckons that you must have meant to uploadand does that anyway when you click Save to finish your post.Inserting inline images needs a few more clicks to accomplish,but it isn ' t a routine without signpostsand should become familiar afterthe first attempts.So,hotlinking,image uploader,inline images - yes,this forum does offer alternatives,Jacques,absolutely.
10 years 9 months ago #17500
by testuserA
Replied by testuserA on topic 596 Arroseuse-balayeuse L.M.V. L.M.V. Road Sweeper/Washer (1960-1963)
test comment
- bakalkeeling
10 years 9 months ago #17501
by bakalkeeling
If you upload images with the file uploader method,you can adda title which will show when the mouse is hovered over the posted image.If you want to caption your inline images,well you ' ll have to addthat as a line of text.There ' s an issue with font formatting - the sizeand familyand colour are not being saved.It ' s something to do with the mechanism designed to strip out malicious code,but I will have to investigate the documentation to resolve.Jacques,regarding your comment #5 - the picture and the dam text separately elements. You entered your text in the text editor panel and uploaded the image in the file uploading panel. That is why you do not see the image mentioned in the text code. Again, this goes back to the fact that their are two ways to upload images.If you had uploaded your image inline (using the Image insert icon from the text editor menu), then you would see the text and image link combined.
- bakalkeeling
10 years 9 months ago #17502
by bakalkeeling
10 years 9 months ago #17518
Replied by buzzer999 on topic 596 Arroseuse-balayeuse L.M.V. L.M.V. Road Sweeper/Washer (1960-1963)
The comment above regarding Dave Kaun is absolutely disgusting.I know how much time Dave has spent on this siteand to have an internet troll make a statement like this is unforgivable.That the committee allow this to happen is absolutely incredible - this is not a friendly site anymore.
Time to create page: 3.438 seconds
