25d Petrol Tank Wagon (1934-50)
12 years 5 months ago #3352 by starni999
Hi all, Just won this one, not in the best condition, and re-painted, so even I would normally have thought twice, BUT I spotted the open cab side and rear windows, making it I think the first run of these from 1934 in plain red, I had to have it, and just hope it arrives OK. Better pictures to follow when it does. s276.photobucket.com/user/starni999/medi...zps350b2c6c.jpg.html ]
[img
s276.photobucket.com/user/starni999/medi...zpse7d0b8bf.jpg.html ]
[img
I have a T1 Redline Glico tanker that this will sit lovely with. I think I will try to strip that paint off if I can, but if it's been on for decades a new coat of red (and a tube of superglue!) might be in order.Chris Warr.
12 years 5 months ago #13353 by Fred7A
Well spotted,
and a nice addition to your fleet of 25 ' s.I just hope it doesn ' t disintegrate in the post.:ohmy:
12 years 5 months ago #13354 by dinkyfan
Very nice find
and quite rare......you just do not see those very early versions with the opens windows.However,
I would have to think twice before attempting to strip
or re - finish that one......it appears somewhat fatigued
and fragile,
and might just crumble with too much spent on it.Terry
12 years 5 months ago #13356 by Dirk Bloem
Hallo Terry et al I this might sound like sacrelidge but let me give it a try.I was wondering,
since this model obviously is in a very bad state of ' decomposition ' would it not be worthwile to preserve it,
and other like it that have got the metal fatigue,
in a solid resin casting.Like ' entumbing ' it in a clear resin so that it remains intact but still enjoyable to the eye.I know of several resings that can be used.Casting it in a vacume chamber would definately cut off the oxigen supply
and prevent the poisoning of the metal cells.(that is what it really comes down to) Let me hear
from
you.Dirk Bloem 154
12 years 5 months ago #13358 by dinkyfan
Dirk ---Since I do not restore or repair, I will defer to others one what you are trying to do. I would guess that you could entomb it in some type of resin, but I know I have heard of others using some type of cement carefully applied to cracking areas to hold it together. I am not sure if there is any other 'coating' that could be applied to shield it from further dampness, or whatever seems to encourage the fatigue. Here is Southern California, it is relatively dry, and none of my pre-war Dinky's with mild fatigue show any signs of worsening after many years...they seem to be stable and are in no danger of falling apart. It will be interesting to hear from others in this regard! Terry
12 years 5 months ago #13364 by dinkycollect
Dirk ' s idea is not bad but one may be able to improve it.Remove the axles
and chasis cover the body in kitchen plastic film build a layer of resin on all the inside surface ad fill all the cracks your body is now strong enough to be striped
and to remove the extra resin respray in
and outside so that 100 % of the metal is covered
and isolated
from
the atmosphere ' s oxygen.It maybe a good idea to use varnish as a primer as some paints remain porous
after
drying.reassemble
and display this very rare item.The problem with zamac corosion is oxygen,
not dampness.Good luck,
I am sure that we all want to see what you will have done with this model,
it is only the second one that I see.
12 years 5 months ago #13386 by starni999
Hi all,
Very glad to say the Tanker has arrived safe
and sound.It is very delicate,
and is now sitting safely in the cabinet.The rear windows are already showing signs of casting flash,
I guess difficulty with this tiny area is why they were filled in........... [img] http: / / i276.photobucket.com / albums / kk15 / starni999 / DSCF3081_zps2011c6d4.jpg [/img] Side windows are fine....... [img] http: / / i276.photobucket.com / albums / kk15 / starni999 / DSCF3082_zps4c34d58a.jpg [/img] Chassis is unpainted underneath,
unlike my other Type 1 Tanker,
injection rings are not so pronounced.... [img] http: / / i276.photobucket.com / albums / kk15 / starni999 / DSCF3083_zps01d86cdb.jpg [/img] Here he is with his younger brother... [img] http: / / i276.photobucket.com / albums / kk15 / starni999 / DSCF3084_zps254bfa07.jpg [/img]
And the rest of the Type 1 family,
still lots of these to get........ [img] http: / / i276.photobucket.com / albums / kk15 / starni999 / DSCF3085_zpsd851edcf.jpg [/img] I ' ll decide what to do about restoration / preservation in the future,
to be honest I ' m a bit scared to handle it at all ! Chris Warr.
12 years 5 months ago #13388 by dinkyfan
Chris --Very interesting to see good closeup photos of these Type 1 trucks. They are so rare, at least here in the states. I have never even seen one in person before, so this is a treat for me. You are right in that those rear windows are already flashing up, and Meccano probably quickly decided that they could not hand file those clean, so just easier to delete them and others like that. You have a very nice collection of these early trucks...thanks for sharing with us! Terry
12 years 5 months ago #13389 by starni999
Thanks Terry,
You are always welcome to come
and have a look in person if you get over here.Thankfully the little Red 25a is now back together
after
it exploded on Christmas night 2012,
the miracle of tweezers
and superglue ! Chris Warr.
Time to create page: 0.629 seconds
