788 Spare Bucket for 966 Marrel Multi-Bucket Unit
11 years 3 months ago #459 by buzzer999
Here are a couple of trade boxes for the Marrel Multi-Bucket
[img]/images/sites/default/files/forum-images/788 TB (4).jpg[/img]
10 years 8 months ago #18092 by fodenway
Am I right in thinking that there were two different castings for the English version of this 'skip'? I have two of the type illustrated above with smooth outer side panels, but seem to remember one I had fifty years ago which had multiple vertical ribs cast in. Was the French version (Unic) either one of these castings (with different tinplate side arms), or a completely different one?
10 years 8 months ago #18096 by dinkycollect
You are absolutely right, there are two very different skip castings for the 966 English issue, one with smooth sides and one with corrugated sides which seems to be scarcer. Which is the earliest one ? When did the change occur ? Jacques.
10 years 7 months ago #18148 by fodenway
Thanks Jacques for your confirmation about the English variations. I am now able to answer my own question regarding the French version from the Unic Multi-Benne - this was a slightly different casting. The two pockets at the bottom rear where the tipper locks engage are noticeably further apart than on the English version. Obviously, the tinplate side arms are different, being permanently pivoted to the lifting arms on early versions and replaced by plastic ones to allow the bucket to be detached from the truck on later models supplied with an open bucket and a tanker skip.
10 years 7 months ago #18149 by Dinkinius
Jacques The only way to learn when the change took place is to check the quality inspection stamp (if any) as well as the original price (if any) on the box. That is after the drawings for the 966 have been perused! Regards Bruce (150) 25 February 2016 #799
10 years 7 months ago #18152 by dinkycollect
Bruce, The problem is that I have never seen one with the corrugated skip other than on pictures, I have not seen the drawing for the skip either. Have you ?
Time to create page: 0.357 seconds
