40a and 158 Riley Saloon (1947-55)
16 years 4 months ago #1198
40a and 158 Riley Saloon (1947-55) was created by buzzer999
Here is a type 2a trade box for the 40A Riley Saloon
What is interesting is the presence of an over label
I suspect that the printer has done the original label with an incorrect stock number.It is not possible to determine what the incorrect number is but it certainly has three digits followed by an A.It could possibly be 120A but I would have to attempt to steam the second label off in order to verify exactly what is there and I do not fancy trying to do that.
16 years 4 months ago #11199
Replied by buzzer999 on topic 40a and 158 Riley Saloon (1947-55)
16 years 4 months ago #11200
by goldenp
Replied by goldenp on topic 40a and 158 Riley Saloon (1947-55)
At the moment you can only load one photo per submission. If you try and add more than one you get the last one multiple times. It is possible to edit and resubmit the post to add multiple images. A new version of the forum software that removes this restriction is currently being tested.
16 years 4 months ago #11201
The other problem is with the counter. I am still a fresh boarder with 27 posts. That is exactly the same as I was 9 months ago, I have done at least 50 or 60. Why do we persist with the counter if it is absolutely meaningless?
16 years 4 months ago #11202
by goldenp
I don't have any control on the counter, part of standard functionality. I note you are now showing 28, I am on 52 will see if it goes to 53 after this.
16 years 4 months ago #11203
by goldenp
It has gone to 53. I will try and count your posts to the Forum, note articles submissions are not included in this count.
16 years 4 months ago #11204
by goldenp
Hi Dave, I have done a search on your username and it returns exactly 28 posts, so I think the counter is working Ok. Peter
16 years 4 months ago #11205
Please look at my post for the Austin Champ in Factory Errors of over nine months ago. At that point my count was 27 the post I did today shows 27. I will go through all the threads one by one and count exactly what I have done, I know it will be more than 27.
16 years 4 months ago #11206
by goldenp
If you use the advanced serch facility you can search on all posts by user name. This is what I did.
16 years 4 months ago #11207
So why am I stuck on 29
16 years 4 months ago #11208
by goldenp
You aren't you are now 30, the counter seems to be working perfectly. I will be now 57 after this post
3 years 3 months ago #24154
by DavidT
Replied by DavidT on topic 40a and 158 Riley Saloon (1947-55)
The reference number under the 40A stuck on label is 130A, this must have been the initial intended reference number before deciding on the 40 series of models.
Time to create page: 0.501 seconds
