986 Thornycroft Mighty Antar with Propeller (1959-61)
11 years 3 months ago #4325
986 Thornycroft Mighty Antar with Propeller (1959-61) was created by dinkyfan
Another large Supertoy that would have been very popular with young boys when it was brought out in June, 1959. This used the same tractor/cab as the Mighty Antar Tank Transporter, but painted in different colors, and it always came with a driver and windows. The low loader trailer was a design unique to this model, and as such, it did not have a spare tire mounted on top like the military version. The propeller is a plastic material, and it is mounted on a sort of pallet. This is turn is held down on the trailer by means of a thin black flexible cord that runs through holes in the trailer bottom. I believe this was discontinued in 1964, so not very rare, but certainly makes a nice display! Terry
10 years 11 months ago #15848
Replied by dinkycollect on topic 986 Thornycroft Mighty Antar with Propeller (1959-61)
The low loader with propeller with yellow hubs must be very rare as I could not find a decent picture. Can one post a picture of this rarity ? Jacques.
10 years 11 months ago #15856
Replied by dinkyfan on topic 986 Thornycroft Mighty Antar with Propeller (1959-61)
Jacques---Sorry I did not read your post better....I thought you were referring to photos of an actual Mighty Antar with a propeller load, but you were talking about a rare version of the Dinky model with yellow wheels. I have not heard of it......is it documented that some exist? Terry
10 years 11 months ago #15857
10 years 11 months ago #15861
by 55Zephyr
Replied by 55Zephyr on topic 986 Thornycroft Mighty Antar with Propeller (1959-61)
Greetings everybody, especially Terry and Bruce, It is good to see your pics of this impressive model - hope you will not take offence if I make a slight correction to your comments: 1 The model was introduced in June 1959, but for the first year or so of production did NOT have windows fitted in the cab - if you look closely at Dave's pics you will see that his 986 does not have glazing. I have three examples of this model - one in a box with the date stamp '659 AR' (June 1959, no glazing) - a second in a box with the date stamp 'SM 9 11' (November 1959, also no glazing) and a third in a box with the date stamp '11 60 MR' (November 1960, this time with window glazing). Of course, there is confusion about it's deletion from the range - Ramsay's shows 1959 to 1961 (incorrect); Richardson quotes 1959 to 1964 (probably correct) and the last reference I can find is in the U.S catalogue for 1963, priced at $4.65. 2 A note about 'Packing Pieces' which is one of my pet topics: The lower packing piece is self-explanatory, just fitting loose inside the box base. But the upper packing piece as shown by both Terry and Bruce is positioned upside-down! It should be fitted with the scored and folded edges facing upwards like this:
This way it holds the model (relatively) firmly inside the box - but the other way up it doesn't do anything! Meccano were particularly careful to make all their packing very functional but at minimal cost. If you look carefully at this packing piece, you will probably see red paint offset (rubs) on the underside of the card protector showing where it has been in contact with the bonnet and side tanks/toolboxes, as on my example here:
So far I have not seen any boxes with the wording 'With Windows' added to the lid text, but am hopeful that there may be such a box out there somewhere. I hope this information is of interest and may assist in the long-term protection of your low loaders and propellors! Regards to all, Adrian.
10 years 11 months ago #15863
Adrian--Thank you so much for pointing us in the right direction! I can't remember where I had read that the Antar with propeller never came without windows, but that was obviously incorrect. And that packing piece sure makes sense. I bought that model years ago, and it is kept in a glass display case, so I had not used the packing for some time when I took the photos...but that should been easy to figure out! Regards, Terry
10 years 11 months ago #15866
Replied by Dinkinius on topic 986 Thornycroft Mighty Antar with Propeller (1959-61)
55Zephyr wrote: 'Greetings everybody, especially Terry and Bruce, It is good to see your pics of this impressive model - hope you will not take offence if I make a slight correction to your comments: 1 The model was introduced in June 1959, but for the first year or so of production did NOT have windows fitted in the cab - if you look closely at Dave's pics you will see that his 986 does not have glazing. I have three examples of this model - one in a box with the date stamp '659 AR' (June 1959, no glazing) - a second in a box with the date stamp 'SM 9 11' (November 1959, also no glazing) and a third in a box with the date stamp '11 60 MR' (November 1960, this time with window glazing). Of course, there is confusion about it's deletion from the range - Ramsay's shows 1959 to 1961 (incorrect); Richardson quotes 1959 to 1964 (probably correct) and the last reference I can find is in the U.S catalogue for 1963, priced at $4.65. 2 A note about 'Packing Pieces' which is one of my pet topics: The lower packing piece is self-explanatory, just fitting loose inside the box base. But the upper packing piece as shown by both Terry and Bruce is positioned upside-down! It should be fitted with the scored and folded edges facing upwards like this: (Image deleted - see actual post) This way it holds the model (relatively) firmly inside the box - but the other way up it doesn't do anything! Meccano were particularly careful to make all their packing very functional but at minimal cost. If you look carefully at this packing piece, you will probably see red paint offset (rubs) on the underside of the card protector showing where it has been in contact with the bonnet and side tanks/toolboxes, as on my example here: (Image deleted - see actual post) So far I have not seen any boxes with the wording 'With Windows' added to the lid text, but am hopeful that there may be such a box out there somewhere. I hope this information is of interest and may assist in the long-term protection of your low loaders and propellors! Regards to all, Adrian.' Morning Adrian Many thanks for the advice you have given us. I thought that was the correct manner of inserting the upper packing piece, except on doing this, the end where the propeller is located is above the lower box and therefor the lid does not sit 'flat'. Apparently the way I have had it has always been thus as the underneath (which would be the upper if fitted correctly!) has slight red rubbings from the Antar's bonnet. As for the date when glazing was fitted, my record of factory stamps takes the date back one month to October 1960. The last month I have listed without window glazing is July 1960. As for the model's last catalogue/leaflet appearance, it does appear in the May 1963 leaflet but out by the September 1964 leaflet. However, the 986 does appear in the December 1964 13th Edition Catalogue, and twice in the 1965 catalogues with the first being in February 7/265/200 (72557/02) and the final time in the August 1965 catalogue 7/865/135 (2 ptg)) So there we have it - typically Meccano fashion - utter confusion! Out by September 1964 according to the Meccano Toys of Quality leaflet and finally out by catalogue after August 1965. My latest quality stamp is dated October 1961. After this date it appears that quality inspection went out the window as I have found very few from 1962 onwards. I too have never seen a box marked 'With Windows'. Kind regards Bruce
10 years 11 months ago #15869
Replied by starni999 on topic 986 Thornycroft Mighty Antar with Propeller (1959-61)
10 years 11 months ago #15874
by 55Zephyr
Greetings everybody, thanks Terry and Chris, and Bruce for your specific catalogue information. I should have checked my catalogues more carefully! However, my research did produce some interesting information that at the end of production, a few models were made with a detachable loader trailer (in similar fashion to the 660 Antar Tank Transporter) and that these variations are quite scarce. The picture of this model showed it with it's box which still had no mention of 'with windows' so maybe this reference was never included on it's box. The detachable-trailer model in NM/boxed condition was sold recently by Vectis for
9 years 2 months ago #18976
Replied by janwerner on topic 986 Thornycroft Mighty Antar with Propeller (1959-61)
there's not much to add to the wealth of information on the 986 here. Three more pictures though, which may be interesting. My example, fitted with windows, bears the stamp 1160MR inside the box lid, so another confirmation that in November 1960 windows were present on this model indeed. The inside also shows traces of red rubbing by the tractor's roof and that the propeller almost caused some penetration of the lid. This complies with the fact that no upper packing pieces are present in the box. Looking at the pictures shown above it cannot be difficult to reproduce them. Also, among my pictorial stuff there is an authentic Hausemann & Htte b/w publicity photo, from the archives of this Dutch Meccano/Dinky Toys agent. They used these for advertisements in newspapers and periodicals and for the 'Na Vijven' magazine, which always included some Meccano Magazine-like pages. I love the simple quality of that image material. It is remarkable that the propeller shown is much more pointed than the final production result. Kind regards, Jan
9 years 2 months ago #19016
Some documentary additions, used for my catalogue description work. Meccano Magazine of August 1950 discusses the Antar Low Loader on pages 354-355. Also the second leaflet of the List of moulded jobs and moulding powders (Memo 20927/2, d.d. 6 July 1959), showing the use of polystyrene for the production of the propeller. Kind regards, Jan
9 years 2 months ago #19021
Thank you Jan for including these additional details, especially the work-sheet for the propeller. Most appreciated. Seeing that you like contemporary photographs of the real McCoy as mentioned in the 38e Armstrong Siddeley Topic, I am attaching a couple of images for your enjoyment, and hopefully others as well!
These are of the two Antars purchased by the Commonwealth Government of Australia to move extremely heavy items such as turbines etc, associated with the construction of the Snowy Mountains Hydroelectricity Scheme, an immense operation that took almost a quarter century to complete. The project commenced on 17 October 1949 and was officially opened on 21 October 1972 with the final work completed in 1974 - a huge undertaking involving the construction of 16 dams and 10 hydro-electric power stations.145 kilometres (90 mi) of tunnel and 80 kilometres (50 mi) of pipelines and aqueducts. Just 2% of the construction work is visible from above ground. A huge undertaking that surprisingly, came in on budget. (See that happen today!!!) Also included are several images of my 986 Mighty Antar Low Loader with Propeller. (One of these days I have to throw caution to the wind (as well as my marriage!!) and obtain a 908 Mighty Antar with Transformer!)
Kind regards Bruce (150) 20160923/986/1146
Time to create page: 0.807 seconds
